ok here it is
Old May 27, 2004 | 10:46 AM
zamboxl's Avatar
Default ok here it is
ok guys, to enyone that knows. You guys know the coolant line that is bored in the block and goes all the way from the front to the back on the side of the block; ok now on the side of the timing chain the hole goes out the side and then it comes out next to the timing chain where the oil pump is mounted. That side right there has a block of plate from the factory, now does anyone know if that plate opens during operation or if is there to keep that end of the line close and it is not sopose to open ever?
