Cam choice
I'd consider the GM Hot Cam, 219/228 112lsa lift .525"/.525" with -.5* of overlap and a nice mild lope idle. In a larger 6.0L engine it'll run even smoother and have better low-end power. I'd pick this any day over the LS6 cam.
BTW you can probably meet you 400FWHP goal with the stock cam, also you can possibly see 400rwhp with the Hot Cam in you larger 6.0 L engine.
Further more you could probably even run a Cam Motion LS 5.7 Stage 4 (228/232 114lsa +4, lift .550"/.540") cam which uses fairly mild cam lobes(55* ramp rate), and only has +2* overlap which will have just a little more lope than the Hot cam, but will still very smooth running and DD friendly while making noticeably more power. IMO, Just to be 100% sure I'd contact Kip at Cam Motion to verify that the lope are mild enough for those springs.
http://store.cammotion.com/57-ls1-34...-compression-4
