5.3 cam swap question
Old Dec 13, 2014 | 11:45 PM
skongolf's Avatar
Default 5.3 cam swap question
I just got a 2005 5.3 engine with 706 heads and 97K miles to put into my 72 Chevelle. Since it is sitting on a stand I thought about swapping the cam before I put it in the car. I found a good deal on a Lunati cam with the following specs:
Duration 214/218
Valve lift .555/.551
LSA 117.5
Unfortunately no part number on it. I want to keep my mpg's but get a little HP boost since it will be a daily driver. Anyway, would that be a viable cam or would i need to do heads or at least valve springs to do the swap?
Just want some feedback.
Old Dec 14, 2014 | 11:48 AM
Mercier's Avatar
For that amount of lift, the stock springs won't cut it. You would need at least some "Z06" valve springs but those can be had cheap($60/set). They are good up to about .570" IIRC.
I would consider that the major difference between a LS1 head and 862/706 is intake valve. Yours are about 1.89" and the LS1 heads are 2 inch. For about $100/head you could take them to a machine shop and have them milled about .030" for increased compression(half a point or so?) and have them cut for LS1-style valves. Would give you more power and breathing room.
See this article. It is mostly stock GM cams but includes a couple of Comp cams as well. It shows you what you can do with a basically stock 5.3. The HP/TQ numbers are at the crank so keep that in mind when comparing wheel numbers of some others, but still eye opening every time I read it re: just how much power you can get out of a basic 5.3.
http://www.hotrod.com/how-to/engine/...st-comparison/
The "hotter" of the stock LS1 cams IMO is a good, cheap way to make the 5.3 more of a "car" engine...it's the exact direction I was headed before I yanked the 5.3 in favor of an LS2.
Hope this helps.
