Zero oil pressure at idle
Old Dec 14, 2014 | 07:13 PM
dantj's Avatar
Default Zero oil pressure at idle
Bought a cheapo 5.3 to drop into my Jeep as a temporary motor, previous owner said it had 135,000 miles on it.
I replaced the rod bearings, and head gaskets.
Started it up, and i have no oil pressure at idle. Maybe 5-7PSI at about 1100rpm.
Pulled the valve covers, 2 or 3 rocker arms have some oil pushing out of them, the rest are dry. Valve train isn't crazy noisy, but there is a little bit of noise.
Checked with 2 manual gauges, at both the cooler adapter, and the stock sender location. Both show the same.
Barbell plug is still in place under the back cover. Noticed a little bit of oil running down from the rear cam bearing.
Swapped in a new Melling M295 pump, with the proper O-Ring, still has the same issue.
Any ideas?
Old Dec 14, 2014 | 08:57 PM
Taxman20's Avatar
Sounds to me that the engine may have been bad when you bought it. Did you get to see it run before you bought it? I would bet it has a bad main bearing.
Old Dec 14, 2014 | 09:00 PM
dantj's Avatar
Nope, never heard it run. $200 Dollar special.
Old Dec 14, 2014 | 09:11 PM
sweet99ss's Avatar
That's what mine did when I spun #1 main bearing....
Old Dec 14, 2014 | 10:12 PM
dantj's Avatar
you hear any unusual noise at all from it? looks like its coming back out.
Old Dec 15, 2014 | 11:16 AM
tim wellington's Avatar
Default no oil pressure
question when you replaced oil pump .on right haND side of oil pump mouting surface .there a plug look like a small freeze plug .was it still tight .if not oil wil just keep returning to the pan .when i replace oil pump i packed plug with jb weld.
Old Dec 16, 2014 | 03:25 AM
Jontall's Avatar
Is the oil pan pick-up clogged up with something?
Old Dec 16, 2014 | 08:11 AM
samuel6731's Avatar
If the motor has been sitting for time and some debris have got in it the filter may have clogged instantly. Happened to a friend of mine. After changing sensors, pump, and all that we changed the filter and there it was.
I doubt this is your case, but worth a thought
