Maximum Block Decking
Old Dec 18, 2014 | 10:26 PM
dhall243's Avatar
Default Maximum Block Decking
Hey guys and gals, I first and formost would like to say, if this has been talked about before, I couldn't find it via Google, Search, nor Stickies.
I'm in the process of building my wife a car, my build will consist of an LS1 block, 4.8L crank and Eagle 6.300 long rods. I really want to run a Diamond Shelf Nitrous Piston but the Piston Compression Distance is 1.115 and with a 9.24 Deck I need in the 1.305 area. Now my questions is, how far can we actually deck these blocks. I need to take the block to a 9.05 deck height to achive a 0 piston to deck clearance. Now before anyone ask as to why I want to build a destroke motor, its basically to compete with the coyote displacemet wise, and for the fact I can rev it to the moon on.
Thanks in advance, Scott.
Old Dec 18, 2014 | 11:02 PM
KCS's Avatar
KCS
Moderator
Or just run a 6.50" length rod...
Callies Compstar H Beam Rods for, SBC. 6.500 Length, 2.100 Journal with ARP2000 bolts
It's an SBC rod, so you'd need to make sure there's clearance between the pin boss and small end of the rod, but it's a lot better than milling almost a 1/4".
