I need camshaft help!! Please
Old Dec 19, 2014 | 07:07 PM
jweyhrauch's Avatar
Default I need camshaft help!! Please
I'm new to the forum and pretty new to ls stuff in general. I have a 97 2wd single cab tacoma that I 5.3 4l60e swapped. The only mods currently done to it are custom 1 3/4" long tubes, exhaust, elec fans and an intake. I'm looking for some advice on a cam choice for the truck. It weights about 2700 lbs, it has 3.73 rear axle and a 27" tall tire. I plan on going into the heads in the near future, as well as a stall converter. I drive it quite often. Mostly highway and back roads. I do want to take it to the track. Tuning is not an issue. I've gotten a couple of recommendations from comp. etc. but I really don't agree with them. They have all been for little 218/220 ish cams. I personally think Id be leaving a lot on the table. I've been considering Brian tooleys stage 1 ls na cam. 223/230 .610"/.573" 115+2 . Any help or advice would be appreciated.
Old Dec 19, 2014 | 07:34 PM
A.R. Shale Targa's Avatar
That Tooley camshaft is a good one but most will suggest the stall first. I'm guessing 3200-3600 range.
Old Dec 19, 2014 | 07:38 PM
99Bluz28's Avatar
Will you be doing any towing, or mainly light to medium sized loads in the bed?
I also agree with A.R. Shale Targa, higher stall TC first before the cam.
Old Dec 21, 2014 | 03:18 AM
raceman14's Avatar
Default Slightly different direction
Just going to hit you from another direction because LS heads are so awesome.
I would work the heads before deciding on the cam because if you increase flow 25cfm that is like 50HP and then you can do some fuel curve changes and that could really be killer.
Remember the engine is an air pump and that is what gets it done bigger cams only access the same head flow for a little longer and usually kill bottom end if they are not designed to the cylinder head flow.
25 years on the Chassis DYno gives me a different perspective than most.
Mark@AlienChassisDYno.com
Old Dec 21, 2014 | 06:44 AM
96capricemgr's Avatar
Is that weight right? 2700lbs?
Much different application but I made the mistake of cam before stall and while the car drove fine it gained no performance at the track. 2700lbs and 3.73s might change make it matter less but I still think it is important.
On the heads first, while I wholly agree heads are the single biggest source of HP on an engine I have also seen cases where tiny little stock cams can not use any more than stock flow.
Take for instance the 5.3l engines from 06-08 they gained what 15hp with the new intake with bigger TB, and an upgrade to 243 heads. I don't know all the cam specs and compression so I won't claim this is a complete picture, but a GM power train engineer told me the intake/TB were worth 6hp by themselves.
Point being I think with a stock truck cam heads won't shine, give it even a mild aftermarket cam and good ported heads and the gains can be huge and make such a lite vehicle feel like a rocket.
Edit:
Went and googled 5.3 cam specs and came up with this.
http://www.hotrod.com/how-to/engine/...st-comparison/
Huge difference in the 5.3 cam vs the LS1 car cam so while a car might make substantial gains with heads alone I don't think a truck will, .030" less lift and 11degrees less intake duration are a big deal.
Old Dec 21, 2014 | 11:17 AM
Fry_'s Avatar
Except for the fact that a stock 5.3 cam only has .466" of lift so for the very short time that the valves are open (only 190*) they'll mostly be in the .25-.4" range where head flow is 50-150 cfm less than it is in the .4-.55 range that a aftermarket cam would keep them for nearly the same amount of time do to the increased lift and duration. I don't think even the best heads available could possibly gain 50 hp on a 5.3 with a stock cam, most cam and full bolt on LS1's gain 40-60 hp when adding better heads.
Also 96capricemgr, I didn't think that 2700 lb number sounded right either so I googled it and it's stock curb weight is only 2560 lbs so 2700 seems pretty believable.
