are all ls crank sprockets the same length?
Old Dec 22, 2014 | 02:11 PM
25thhawk's Avatar
Default are all ls crank sprockets the same length?
I need to know if the ls1 vette and lq9 truck sprockets are the same length, before I press it back on the crank. Thanks
Old Dec 23, 2014 | 11:33 AM
Inflame's Avatar
No they are different. The truck sprocket is offset further than the vette. There are 3 different offsets.
Truck - Furthest
F-Body/GTO - Middle
Vette/CTS-V - Closest
Old Dec 23, 2014 | 02:25 PM
thunderstruck507's Avatar
I believe you are confused...the accessories and crank PULLEY are as you describe, the crank timing chain sprockets are the same to my knowledge.
Old Dec 23, 2014 | 03:24 PM
25thhawk's Avatar
Exactly what i was looking for. I know the crank pulleys all have different offsets, but I was concerned about the timing chain crank gear/ oil pump gear. I measured off of another motor and it was within .02, so i am assuming I am good.
Old Dec 23, 2014 | 04:15 PM
thompson's Avatar
The timing gear/sprocket is the same on all wet sump ls motors. Both the LS1 and LQ9 are the same.
Old Dec 24, 2014 | 05:58 AM
25thhawk's Avatar
Thanks
