What piston to use to get 11-1 compression for ls1
Old Dec 31, 2014 | 04:11 AM
metlic53's Avatar
Default What piston to use to get 11-1 compression for ls1
I have some 243s with 62cc chambers. What piston would I run to get 11.0-1 compression? -2cc,,,,-3cc???
Thanks
Old Dec 31, 2014 | 06:07 AM
A.R. Shale Targa's Avatar
with factory pictons and GM head gaskets you already have 10.9 to one
.045" Cometics would be 11.15 range and .040" gaskets has you around 11.3
If you need the valve relifs to clear a big *** camshaft then go -2cc with .040 combo
