Head gasket id and problem
Old Jan 1, 2015 | 01:16 AM
occhevelle's Avatar
Default Head gasket id and problem
I bought some used 243 heads and they came with gaskets. I was told they were stock GM, but I wanted to know before I put them on. The other issue is that there is a crease in one and wanted to make sure that wouldn't cause a problem. There are no stampings or anything on them to help me id them (that I can see).
Any ideas on what gaskets these are and if they're good to install?
Old Jan 1, 2015 | 01:19 AM
Burken01's Avatar
I wouldn't use em.. They're $45-$50 new why risk it
You don't wanna have to tear the heads off after its done to re-do them if you run into a problem
