Cam only, do I need gears?
A part of me wants to do the gears because they're much cheaper than a full cam setup and tune, but if I can save that money and put it towards a cam I'll be that much closer.
Anyone run a cam only on stock gears?
What about stock cam with 390s?
Thoughts?
Thanks
With stock gears and an aftermarket cam 6th will be about unusable at legal speeds.
Also some guys running the 1/8 might get by in third with the 3.90s, tire size plays into gear choice as well 28" tire with 4.10 acts as a number ally lower gear than 3.90 with 26".
Point being there is some more to understanding thing than "some guys like"
Most LS1s are 28lbs injectors right? 30lbs is enough for over 500rwhp through an automatic if you look at AFR rather than DC. Doubt a cam only setup really maxed out 28lbs.
While on the subject the 80-85% rule is wrong too beside not having an easy accurate,way to monitor. People claim it is hard on the injectors but then send them out for flow testing where they run them open for a minute. On the car they have brief moments at the top of each gear where they might be near max DC, take a lot OD 10-11 second passes to equal the amount of time flow testing keeps them wide open.
Keeping the injector on the small side improves low speed performance and serious racers find a better 60ft.
Now an argument like wanting the better injector marching of aftermarket or being concerned about a 12yo pump are better arguments.
I've read a ton about the shitty 10 bolt, I'm runnin nitto 555s and don't ever launch it, it should be fine.... If it doesn't then I have an excuse to upgrade!
