Need some help with gaskets
Old Jan 12, 2015 | 09:37 AM
Redfire LS's Avatar
Default Need some help with gaskets
I'm new to these LS based motors and I have a 6.0L LQ4 motor out of a truck/suv and I need an oil pan gasket, a valve cover gasket and it has a coolant leak that looks to be coming from the thermostat housing. I have not taken that apart yet so i'm not sure if it's just a leaking seal/gasket or exactly what is causing it, so if anyone can give me some advice and maybe some part numbers i would appreciate it!
Old Jan 12, 2015 | 10:16 AM
76larkman's Avatar
get your gaskets for the truck application. your leak could be tired water pump. there is a weep hole bottom side of pulley. if its been leaking you should see a trail of green.
Old Jan 12, 2015 | 10:47 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
GM oil pan gasket is part # 12612350. We keep them in stock.
http://www.texas-speed.com/p-215-gm-...an-gasket.aspx
As mentioned, I'd check to make sure that the water pump isn't leaking first. We keep all of the bolts/gaskets in stock, so let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 13, 2015 | 06:16 PM
Redfire LS's Avatar
thanks! what about the drivers side valve cover?
