not starting after cam swap
Old Jan 18, 2015 | 09:15 PM
zwilloughby's Avatar
thats exactly what i had it at when i set it, the only thing i could think of is timing jumped on me, replacing the plugs because they were soaked in gas. I'm kind of hoping it the timing because i cant think of anything else it would be.
Old Jan 19, 2015 | 08:52 AM
redbird555's Avatar
if the plugs are soaked in gas hve you actually verified you have spark? I would go get a spark plug tester at the store if you dont have one and check all the plugs you can. Only takes 10-15 min
Old Jan 19, 2015 | 08:59 AM
thunderstruck507's Avatar
check the crank sensor and wiring, does the tach move when cranking?
Old Jan 22, 2015 | 11:23 AM
Found out timing was off by about only 90° no big deal...
Old Jan 22, 2015 | 04:03 PM
redbird555's Avatar
so the timing chain was off a few teeth?
Old Jan 23, 2015 | 07:16 AM
vettenuts's Avatar
You might have damaged the valves if it is off that much.
