87 octane + meth? Need advice
Old Jan 20, 2015 | 07:44 PM
josh4ku's Avatar
Default 87 octane + meth? Need advice
[B][B]Well I am building a 95% street prochargedo trans am. Build thread is here:https://ls1tech.com/forums/forced-in...ld-thread.html
The only pump gas that is available in the town I live in is 87. I really don't want to have to drive 30 miles every time to fuel up or stock my own 91 octane fuel. 91 is the highest available within 60+ miles. My questions is with 10:11 CR and 15-18psi boost will 87 & methanol be ok to tune Up to 800-900rwhp?
Old Jan 20, 2015 | 10:04 PM
LS1-450's Avatar
Originally Posted by josh4ku
Well I am building a 95% street turbo trans am. Build thread is here:https://ls1tech.com/forums/forced-in...ld-thread.html
The only pump gas that is available in the town I live in is 87. I really don't want to have to drive 30 miles every time to fuel up or stock my own 91 octane fuel. 91 is the highest available within 60+ miles. My questions is with 9.6:1 CR will 87 & methanol be ok to tune on up to so much boost after that just tune on 110 race fuel for race days?? Or will 87 not even be enough for cruising and mid throttle ?? If its absolutely stupid than i will just deal with it. I have a lot of money in this engine so I definitely don't want to be melting pistons because of fuel. My t4 turbo will probably max out at 800 rwhp I'm guessing. I would still like to run the car 600-700hp on the street.
Don't forget that you can also add Toulene or Xylene to 87 to boost the Octane. Be sure to post this in the "Forced Induction" section. They'll know if 87 is enough w/ meth.
Would assume that with low enough timing 87 is tunable.
Old Jan 21, 2015 | 05:37 AM
farmington's Avatar
so happy all the stations here have 93 what about E85?
Old Jan 21, 2015 | 06:04 AM
josh4ku's Avatar
I don't know I keep thinking e85 but then it's still the same thing it's 45 miles away. And that's the only place I know of. No road trips more than 150 miles on e85. Plus possibility of gumming injectors doesn't excite me to much
Old Jan 21, 2015 | 07:53 PM
blackandgold's Avatar
I thought I had it rough with only 91 in Socal.
Old Sep 7, 2016 | 06:33 AM
josh4ku's Avatar
Going to try to bring this back alive. E85 station is going away here so now I am stuck with 87 and meth again. Never did try it before.
Old Sep 7, 2016 | 06:43 AM
JoeNova's Avatar
Restricted User
10:1 + 18 PSI + 87 = boom.
Old Sep 7, 2016 | 06:50 AM
josh4ku's Avatar
you say that here but yet you make a post about meth and 91 saved your engine at 29psi....so why can't meth and 87 run ok at 18psi
Old Sep 7, 2016 | 06:51 AM
josh4ku's Avatar
But if that is true I may just run a 32 oz of octane booster like BOOSTane to make it about 95-96 octane
Old Sep 7, 2016 | 06:53 AM
ramairetransam's Avatar
your going to have to try it. Its all you can get , so you may need a 2.5 gallon meth tank in the trunk bc i bet you will be spraying any time your in boost so you will use a ton . But have to keep timing low and build it up .
Going to be a learning curve .
Old Sep 7, 2016 | 07:24 AM
JoeNova's Avatar
Restricted User
93 and water/meth, not 91.
Not only that, but it was for a ~2 second pull. Tires spun hard, I let off. Water/meth is the only reason it stayed together. I never said it ran well enough at 29 PSI to do it again.
If you run 87 with meth and try to stay in it for any amount of time, its going to start knocking hard. Sure, you could get away with a few pulls, but at some point its likely going to blow.
I just noticed you have a forged shortblock, which will definitely help. But if you're building a completely custom setup, why not get one that has a more 87 friendly compression ratio?
Old Sep 7, 2016 | 07:32 AM
josh4ku's Avatar
becaise I thought I was going to have E85 here found out yesterday they are going to quit selling it. Well crap. i guess I had better mix octane booster with each tank to upper 90s and run the meth. Surely that would be safe.
Old Sep 7, 2016 | 07:40 AM
josh4ku's Avatar
or maybe I should just keep the boost down around 12 psi. It's not like it's an all out race car. Street/strip.
Old Sep 7, 2016 | 07:44 AM
josh4ku's Avatar
Another option I guess is to find a fuel tank and drive 120 miles to fill it up with e85 and bring it back home lol
Old Sep 7, 2016 | 07:59 AM
JoeNova's Avatar
Restricted User
Octane boosters really don't work as well as advertised, so be careful which one you pick. Some claim to be made of 110 octane race fuel, but adding a 12 oz bottle of 110 to 15 gallons of 87 MIGHT give you 88 octane based on test method.
Make sure you get a decent one. I've used the VP Racing Octanium a few times with good results. Its usually available at the local parts store but its not cheap. $25 or so for a 32 oz bottle. That added to half a tank of 87 should give you just over 94 octane (or so their octane report shows).
Old Sep 7, 2016 | 03:39 PM
kingtal0n's Avatar
Pretty sure you can just find some toluene locally (try paint supply stores) someone is bound to have it in cheap big barrels. I found some at a local tile place, they didn't even know it could be used as "gas" looked at me real funny when I asked how much I could buy at once to "burn" because it is also used to make TNT (i.e. Tri Nitro Toluene) and who knows what else
Old Sep 8, 2016 | 03:03 PM
josh4ku's Avatar
Spoke with the guys at boostane. Sounds like they have a really good product now. Planning to use it Mixed to 98 octane with the methanol .
