ARP Rod Bolts
Old Jan 23, 2015 | 05:06 PM
shepss217's Avatar
Default ARP Rod Bolts
I was thinking about upgrading my rod bolts to ARP's for my 02 z28, which part number do i need and will it really help to upgrade them?
Old Jan 23, 2015 | 05:23 PM
KCS's Avatar
KCS
Moderator
Nah, don't bother.
Old Jan 23, 2015 | 05:27 PM
shepss217's Avatar
Ok not trying to be a dick but what would the reasoning be? I will be spraying the motor up to a 200 shot possibly plus the heads and cam already on top of it. Just curious is all
Old Jan 23, 2015 | 05:28 PM
JakeFusion's Avatar
Super Hulk Smash
I'd leave it alone. I did it. I figure I'm on borrowed time. You really should resize the rods when you do it. Otherwise, the bearing will give way because it is out of round. I didn't, which is why I figure I'm on borrowed time. But this was to hold me until I went with a 402 or something.
The PN tho is ARP 234-6301
Old Jan 23, 2015 | 05:34 PM
shepss217's Avatar
Ok yeah i aint trying to get into all that, i will build an lq4 before i mess with all that
Old Jan 23, 2015 | 06:01 PM
redbird555's Avatar
ya you already have the ls6 bolts which are good to 6800 rpm and many people have taken them well over that. The nitrous, H/C wont harm the bolts. Rpm is what kills bolts not hp
Old Jan 23, 2015 | 07:07 PM
shepss217's Avatar
Ok i just got the car tuned to rev to 7,000 but it shifts between 6,700-6,800
Old Jan 24, 2015 | 02:39 PM
VandykeT/A's Avatar
I turned a stock bottom to 7100. If you change just the bolts you risk distorting the rod cap causing a bearing to turn. Leave it alone unless you want to resize the rods. I think you'll be fine staying at 7k.
Old Jan 29, 2015 | 10:23 PM
Inflame's Avatar
Deff resize the rods when you go ARP rod bolts. I did and mine had to get larger bearings due to the distortion from the rod bolts.
Old Jan 29, 2015 | 11:18 PM
KCS's Avatar
KCS
Moderator
Same here.
