Low Compression Before Break-in
Old Jan 24, 2015 | 01:04 AM
Lethalwx69's Avatar
Default Low Compression Before Break-in
I have a LQ4, new block, rods, pistons, and rings. I took my time and made sure everything was oriented correctly, while assembling the shortblock. I just got my head gaskets in so I put those on. I then decide to put a spark plug in each cylinder and give it a couple turns. So I turn the crank maybe a 1/4 turn when I started to feel some resistance, and then pssst!!! Air is leaking passed the rings, it scared me at first, but I figured it was because the rings haven't seated. I tried another cylinder same thing happened. I don't have a gauge so I just went by feel. Is this normal?
Old Jan 24, 2015 | 06:56 AM
Pb Foot's Avatar
The piston rings do not create an airtight seal. At rpm the pressure does not have as much time to leak down. Normal operation
Old Jan 24, 2015 | 07:31 AM
JRENIGAR's Avatar
If the system is primed up with oil then remove the plugs and install a comp checker. Jump power to the starter and check the comp the correct way. Report back what the readings are.
Old Jan 24, 2015 | 08:43 AM
96capricemgr's Avatar
Who knows what pre break in compression should be on his setup?
Old Jan 24, 2015 | 02:35 PM
VandykeT/A's Avatar
Any engine will have that psst sound when you turn the motor over by hand with plugs in it.
Old Jan 24, 2015 | 02:37 PM
svede1212's Avatar
Combustion forces the compression ring out to seal
Old Jan 24, 2015 | 03:35 PM
RockinWs6's Avatar
Its normal, all engines leak down about 10%.
Old Jan 24, 2015 | 04:22 PM
Lethalwx69's Avatar
Thanks for all the info.
I'll do that for sure when I get the engine back in.
Old Jan 24, 2015 | 04:52 PM
Agreed it sounds normal, my last post was more a challenge for those say to do a test
