Johnson 2110R Lifter Preload?
http://johnsonlifters.com/Products/H...ers/2110R.aspx
I'm thinking .025- .030 like the Morels, but I wanted to double check.
Also, if you are using the Johnson 2110R's, I'd be interested to hear your combo and what length you came up with.
I typically tell people with 2110's to set preload @ .040" +/- .010". The same goes for the 2110R that has .045" less travel than the standard 2110's.
I measured all 16 on my ride. All were within .006-.008 of each other and my Manton pushrods were all within about .004 of each other. So I just tried to match them best as I could since I ordered them all around the same length. But I felt good knowing they were all basically within .010" of each other.
