Piston choice for N/A?
However, if you are keeping it N/A on a 5.3, your most economical solution is to get some Gen IV 4.8/5.3 pistons because they are flattops. You won't have valve reliefs with the GM pistons, so just remember to measure your valve clearances with whatever cam you select.
For reference, I have those pistons with 862 heads on a 5.3 and compression is right at 10.5:1 with GM .051 head gaskets.
The rule of thumb is 1cc for every .006" milled off the deck. So, with .005 taken off, you're probably at or just under 66cc. Another .015" would get you to where you want to be. However, you will need to see where your pistons are in relation to the deck at TDC.
Keeping the same numbers I used before, but switching to a .040 gasket, 66cc chambers would be at ~10.9:1 and 65cc would be ~11.09:1. Again, the major assumption being that the piston comes .005" out of the hole.
Mahle and Autotec have the 4032 forgings which are an upgrade over the hypers.
