Comp ratio of 5.3 vs. 6.0 head
I was going to try 2 acchive 10:1 w/ the 5.3 heads then put the 6.0 heads on to drop the comp back down when I get the turbo stuff. If i got the 10:1 w/ the 53 heads what would by comp be w/ the 60 heads?
Thanks
Robert
There is a really good thread here relating to this exact question. It is usually at the top of the forum. Use the link below and good luck! Keep us up on the build.
https://ls1tech.com/forums/advanced-engineering-tech/111207-ls1-head-combustion-chamber-cc-volume-vs-cr.html
