oil cooler??
Old May 30, 2004 | 02:23 PM
soundengineer's Avatar
Default oil cooler??
any of our sponsors sell any oil cooler kits??
Old May 30, 2004 | 09:07 PM
Ragtop 99's Avatar
I haven't looked for one so maybe a place like TR or Speed might carry one, but why do you think you need one?
Old May 31, 2004 | 06:02 AM
mitchntx's Avatar
Maybe this can help ...
http://frrax.com/rrforum/index.php?a...8&hl=radiator&
It's a parts list for the plumbing. My oil cooler is a heat exchanger inside a side tank of my LGM radiator. But, you can use the parts list and source your own oil cooler.
I like this setup because it doesn't require a remote oil filter or a sandwich plate that makes the filter hang even lower. Also, a sandwich plate has the ports coming out perpendicular to the block, which is straight into the hearder. LGM's adaptor has the oil line ports coming out parallel to the block, away from the heat.
HTH
Old Jun 1, 2004 | 08:35 AM
its not a need...its a want....
to help detur possible detonations from high compression and high heat....
cooler oil...lower temperatures....on all parts...
Old Jun 1, 2004 | 08:36 AM
HTH
thanks for the link....
I will probably try this one...
