5.3 Ring gap
Old Feb 15, 2015 | 09:06 AM
SupaDupaSteve's Avatar
Default 5.3 Ring gap
I've got an L33 that I'm rebuilding. Keeping stock crank and rods, put a set of sealed power pistons in because the stock ones had wear on the skirts. Anyways... I bought the appropriate rings for them P/N E-937K
The rings came and are separated within the package. They are also identified by where the bevel is at on the inside. The installation instructions don't say anything about checking gap.
I obviously checked the gap, and on the first 2 (top and middle) and the top ring gap was .020 and the second was .014.
Now this goes against everything I've researched and what I learned in school. It's a mild NA 5.3 (3.780 bore) so .004x3.780 = .015 and the second should be about 20% larger so .018..
Why are these rings backwards? I've checked multiple rings in multiple cylinders and they are all about the same.
Old Feb 15, 2015 | 11:52 AM
Dug out the old pistons and rings and measured those. .031 on top and second rings. I can't find the GM sepc for ring gap for a 5.3 either, only LS1
Old Feb 15, 2015 | 06:12 PM
A.R. Shale Targa's Avatar
the Grand Sport LS3 I just checked was at .012"/.022"
Old Feb 15, 2015 | 06:52 PM
monte383sbc's Avatar
the normal ring gap in theory for a N/A engine is .004 per inch bore, now if your block hasent been machined or honed at a machine shop I would check the ring end gap half way down the bore, you can use a flat top piston to push the rings down into the bore, if I were you I would go by what that manufacture of the ring tells your to gap them, I usally gap my second rings .002 larger then the top rings for the gases to escape from in between the rings, a cracked ring land could ruin your day. I wouldn't sweat the .020 gap on your top ring that is if you are sure you don't have the rings mixed up, good luck I hope this helps
Old Feb 15, 2015 | 07:06 PM
correct. and no, it's original, never been machined. That's where I've been checking ring gap. and that's the thing, the manufacturer has no specs for the rings, nor the pistons. I wouldn't be so worried about the .020 if the second gap was something that made sense, but it being smaller doesn't make sense. These aren't file fit rings and having a gap that small below a larger gap can't be right.
Old Feb 16, 2015 | 05:03 PM
Bump... anyone? I'd really like to have some kind of resolution to this issue.
Old Feb 16, 2015 | 05:41 PM
If you don't have the rings reversed or mixed up then just gap the second one at .024"-.026" and be done with it.
You'll be safe for mild spray or boost as well
