Symptoms of missing oil pressure "barbell"
With all the plugs pulled cranking I get very miniscule oil pressure 3-4psi. And it will occasionally bounce up to 20ish then fall back to nothing. I tried pre lubing at oil port on the front of the engine... no luck. Doubt it's a priming issue. 100% sure I got he O-ring on the pickup in and seated properly. Pretty sure it's the barbell.
thanks.
I went through the same exact process as you did except for, mine WAS installed in the block and all of this was for nothing...
thanks.
i think I forgot the plug too. My oil pressure cranks to 20then heats up and drops to 10ish my lifters or rocker arms make noise too think is cause of that?
Do a teardown and put it back in. If you read this thread you should know all this by now.
I have a gen4 l92 block and I'm pretty sure the plug above the oil filter is the same one (gen3 vs gen4??) we are talking about here but what I don't know is what I'm looking for and where I'm looking for it.
I know what a barbell looks like just not sure exactly how obvious it's gonna be when I get in there so I thought I'd ask.
I'll have the plug pulled tomorrow and I'll get a photo if I can.
Okay so here is a pic of the view of a missing barbell when looking thru the removed oil plug above the oil filter
https://photos.app.goo.gl/LSVJRougvhvosEqVA
So I pulled it off the stand and pulled the back cover, you can see the barbell is indeed missing and that you would easily see the "bar" when looking thru the oil plug access hole, you could easily feel for the bar as well as the bar is close to the access hole.
https://photos.app.goo.gl/jfoivUJ11p3SxvT79
* Way better than Forcefeds day
https://photos.app.goo.gl/TcyzCtsSLJ7NSSzu7
Got it back together and primed like a champ.
https://photos.app.goo.gl/eLT8b73eu24b1p6CA
https://photos.app.goo.gl/cq4ETnsveXi1Hjrk9
