Good machine shop in the Albany area?
Work I need done are machine block for pistons, deck block if needed, line hone mains with studs, clean, install cam bearings, balance rotating assembly, check for proper clearances that I spec and order correct bearings.
I will run the car on a dyno after it's all sorted out. I have a base tune already that should be fairly close. I will let the Holley system get the tune closer and then take it to get some numbers. Does Tony have a chassis dyno also? Where about in Balston Spa is his shop?
