which vale springs?
Old Feb 23, 2015 | 06:25 AM
LoneSStar's Avatar
Default which vale springs?
wanted to get opinions on which spring would be better for a 609. lift cam ?,..
the EHT 650.'s or the 675's?...dont wanna go overkill but also dont want spring failure...thanks guys!!!
Old Feb 23, 2015 | 07:00 AM
Tuskyz28's Avatar
Btr 660 springs are top notch for what they cost.....
Old Feb 23, 2015 | 03:25 PM
redtan's Avatar
Depends on the valves and lobes you have.
For smooth, easy lobes and a lightweight valve I'd go with some PSI 1511MLs. For harsher lobes with a heavy SS valve I'd go with the BTR duals as mentioned above.
Old Feb 23, 2015 | 04:11 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The PRC .650" dual spring kit with titanium retainers will work great, and they're on sale for $279.99!
https://www.texas-speed.com/p-474-pr...retainers.aspx
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 24, 2015 | 12:31 PM
LoneSStar's Avatar
sweet thanx guys! would a comp rocker trunion upgrade kit be worth doing as well?? cam is 233/239 598./610
Old Feb 24, 2015 | 04:06 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I'd pass on the Comp kit and get the ones BTR sells. They're a higher quality.
