VRX2 cam, are dual spring necessary?
Old Feb 24, 2015 | 09:05 AM
Wicked 94TA's Avatar
Default VRX2 cam, are dual spring necessary?
I just bought a Vengeance VRX2 cam. The specs are 224/228 .581/.588 114 LSA. Does anybody else on here have this cam? Are dual valve springs necessary?
Old Feb 24, 2015 | 09:06 AM
TurboBuick6's Avatar
No they are not. A good beehive will be more than enough.
Old Feb 24, 2015 | 09:19 AM
I found the Brian Tooley dual kit for $219, a pretty good deal I think. Will those spring fit a stock 241 head or will the spring seats have to be modified?
Old Feb 24, 2015 | 09:33 AM
They will fit without modification.
Old Feb 24, 2015 | 09:59 AM
With a somewhat small cam as the VRX2, will the stock injectors still be ok?
Old Feb 24, 2015 | 10:32 AM
HCI2000SS's Avatar
Stock injectors should get you by
Old Feb 24, 2015 | 11:43 AM
JakeFusion's Avatar
Super Hulk Smash
I'd run duals because that cam uses XE-R lobes. Even tho maximum lift isn't much, the lobe intensity is pretty good.
