LQ4 with 04 Ls6 Cam
Old Feb 25, 2015 | 05:06 PM
mvrotc's Avatar
Default LQ4 with 04 Ls6 Cam
Hey guys i have a 2001 LQ4 Thats ready to go into my 99 z28 , i also have an 04 ls6 cam on the shelf with everything needed to throw it in , i see that most of the lq4 motors that are in bolt on CARS not trucks dyno around 320 hp / 330 torque to the wheels. In my car it will have ls6 intake , long tubes ory, slp loudmouth , UD pulley. MY question is , is it worth it to swap in the ls6 cam? im concerned with the low 9:5 compression ration, this isnt an all out build or anything id be happy with 360-370 wheel as a nice weekend driver. To make the ls6 cam happy would i have to put in the 243 heads as well to bump CR ?
Looking for opinions
Old Feb 25, 2015 | 08:12 PM
KCS's Avatar
KCS
Moderator
I think that low compression ratio is your biggest enemy. The 243/799 heads would help but I don't think the LS6 cam will do much either way.
Old Feb 25, 2015 | 08:52 PM
mvrotc's Avatar
How about something along the lines of a 228r on 112 LSA , will that make decent numbers with the 9:5 cr?
Old Feb 26, 2015 | 09:54 AM
gagliano7's Avatar
Here is a lq9 with the ls6 cam to the wheels.
Old Feb 26, 2015 | 01:05 PM
whatsa347's Avatar
More cam isn't going to make a low compression motor better, get a set of 5.3 heads or something, anything to make the compression a little higher. I had an LS6 crate motor and in a lighter car with higher compression it was still pretty lazy down low.
Old Feb 26, 2015 | 07:03 PM
mvrotc's Avatar
I actually have a set of 862 heads I contemplated tossing on there
