4"stroke vs stock 3.622 stroke
Old Mar 24, 2015 | 05:47 PM
Chris'stransam's Avatar
Default 4"stroke vs stock 3.622 stroke
I have a Lq4 block for my 99 transam . I plan just honing the bore if i can get away with it . But here come the question . How much am i leaving on the table if i reuse the stock crank vs 4" if the motor is built the same way ? I plan on nice healthy blower cam , set of lsa heads & set of blower wise I pistons and my Novi 2200 SL supercharger with 18psi .
Old Mar 24, 2015 | 07:07 PM
96capricemgr's Avatar
If adding a blower I would save the money and use the stock crank.
Displacement is the most expensive way to add power. Lots of coin for relatively little gain compared to spending money on heads cam etc.
If you have the budget to do it all WELL go for it, but if the stroker crank will cause you to cut a corner say not porting heads or something then skip it.
Old Mar 24, 2015 | 08:27 PM
MuhThugga's Avatar
You will need new rods and pistons to match that 4" stroke crank. You can't just reuse the stock stuff.
Old Mar 24, 2015 | 09:19 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
^^^^^^^ AGREED ^^^^^^^
Put that money toward a set of MMS220s better value then extra
Stroke in FI application!
Old Mar 25, 2015 | 12:40 PM
Darth_V8r's Avatar
Moderator
With a centrifugal supercharger, I would keep the stroke shorter, since you'll be winding it out quite a bit. Longer stroke makes faster RPMs harder on parts, because they have to travel further in the same amount of time, and they see higher accelration rates at the extremes.
If you were using a roots type blower and looking for ground pounding torque, I'd say stroke it. Mostly, by not stroking, you're giving up low end torque.
Old Mar 25, 2015 | 04:13 PM
VandykeT/A's Avatar
If you were N/A you'd be giving up 50 or so ftlbs but since your FI I would reuse the stock crank and do forged rods, pistons, main and head studs and go with it.
Old Nov 11, 2024 | 08:36 AM
mozmale's Avatar
For future readers:
There is no replacement for displacement. This concludes Engines 101.
Old Nov 11, 2024 | 08:49 AM
grubinski's Avatar
In before G Atsma
Old Nov 11, 2024 | 09:59 AM
the_merv's Avatar
Veteran: Air Force
How are people digging up these old threads....
Old Nov 11, 2024 | 10:25 AM
Originally Posted by grubinski
In before G Atsma
Hey lighten up! LOL!
I just got up, man!
Good catch, though....
