Head Work
Old Mar 25, 2015 | 08:46 AM
Cody5's Avatar
Default Head Work
Hey guys I have a set of 862 heads for a 5.3. I sent them to my shop and he ported and polished them and gasket matched them. What exactly does "port and polish" mean? I know what gasket matching is. Also, will a set of heads with this work done to them perform a lot different than stock? Thanks Guys!!
Old Mar 25, 2015 | 08:54 AM
96capricemgr's Avatar
I wouldn't trust a guy that uses the very 1970s phrase port and polish, gasket match isn't necessarily good either, can create a fat spot in the middle of the combined intake port.
Old Mar 25, 2015 | 09:47 AM
KCS's Avatar
KCS
Moderator
Port and polish means just that; they're ported and polished. "Ported" is when the ports will typically be sized and shaped with a carbide grinder first, then "polished" with sandpaper rolls to smooth out the rough finish. With the popularity of CNC machines nowadays, ports aren't really polished anymore unless someone hand finishes them.
Gasket Match is a term that makes me cringe though. If anything, that's a term that should have been retired or completed excluded from the LS community around 1997. As far as the old school engines, people would actually open a port up to the gasket opening. The problem is that the gasket manufacturer has no idea how big your port needs to be and are often much larger than the port, so a true gasket match causes an expansion or bulge in the port and the manifold to cylinder head flange. This is bad for airflow.
The LS engines for the most part, use an O-ring to seal rather than a gasket, so you don't want to open up a port to the O-ring groove unless you go to a custom gasket. What you really want is a Port Match, where the runner from the intake manifold to the cylinder head makes a smooth transition without the huge bulge.
Old Mar 25, 2015 | 02:36 PM
redtan's Avatar
Most of the time people (or porters rather) polish the exhaust runner and/or the combustion chamber. On the intake side it's best to leave a textured/rougher surface rather than a mirror polish.
And gasket matching is quite possibly the worst thing you can do on the intake side. It opens up the runner and slows down airflow into the rest of the runner. If he enlarged the rest of the runner accordingly fine I guess you can go with a big sized runner, but just opening up the mouth and leaving the rest the orignal size is a poor thing to do in today's heads.
Maybe he meant gasket matching on the exhaust side which is ok, but without knowing the size of the primaries once again that can prove to be problematic.
Old Apr 22, 2015 | 09:32 AM
kad5118's Avatar
what would you advise for the intake port runner for 706 heads for 4.8. I have a compro intake that I plan on running with my ported heads however I was just wondering if I should also. Match the runners from the intake to smooth it out with 80 my grit sandpaper. would that destroy the velocity for that head or would I be in the safe zone still
