good rotating assembly for mild boost
I've recently been having issues with my motor. After a year of peril (ptv contact and rouge problems) I've decided to pull the motor and get the short block rebuilt. I'm putting in high performance cam bearings on top of the normal overhaul of gaskets, rings, bearing etc. I am also getting forged internals. I know right now I have a very aggressive cam but in the future I would like to go with a mild boost setup and a smaller cam. Those are my future goals but I would like to know what is a good place to start for my internals setup that will support my ms4 for cam for now, and also be good for boost in the future. The car will be getting 3.90s and a new rear in the future as well. I am looking for a car I can drive around from time to time, sacrificing some drivablility of course, but more importantly be able to perform at the track. Any input is appreciated. Thanks
I plan on being at 6-650 rwhp all said and done. Do you definitely suggest a new crank. This current motor has 30k on it so I originally planned on reusing that crank unless we found damaged after motor was opened up
