Best head and cam package ?
I'd go with the T3, of it was STRICTLY between those 2.
Not sure about the 225 but with my livernois stage 3 LS6 im running them as is out the box with stock gm gasket.
I would look into the PRC 227s.. your best bet is to keep your setup simple. I couldnt get an answer as well if my cam would clear milling my heads. So i run them as is and played it safe.
Play it safe and keep it simple..
Id go with prc 227 out the box and 233/239 cam. If you wanted a even budget setup .... look into some PRC 5.3 and that cam.
Theres endless results of that combo.
