Going fast in California...
Anyways, I am getting close to pulling the trigger on some parts. does the ws6 store have a similar return policy to summit racing? Summit seems a little more expensive, but I have had really really good luck returning items to them.
is this http://www.ws6project.com/user_stor/...hell-replacem/ a port/polished version of http://www.ws6project.com/user_stor/...r-ls1-ls2-ls6/ ? Seems worth the extra $ if it is. I just want to make sure I am not missing anything. They both have EGR for us 2000 guys ya?
heads:
http://www.ws6project.com/user_stor/...oducts_id=4558
got some more research to do to get the right cam. Thanks for all your help
You've got to know that eventually moving to another state won't be a option worth even considering with all "climate change" fear mongering going on in politics. Eventually all states will have the same screwed-up emission standards like California. It's not a matter of if it will happen, but when.
I would have make a few changes to be friends with the EPA.
As far as heads go you can save $1000 dollars by sending your heads in for CNC porting compared to buying the AFR heads.
It ultimately your money and you can spend it how you want. But I think for a smog build aftermarket castings, and a 102 is way overkill. You can use the saved money on an underdrive pulley and a ram air, or electronic cut out ect.
Not saying ported 243s are bad but unless you get a good deal on a set already ported (which is what I went with those myself) you're not saving that much compared to an aftermarket casting that will undoubtedly make more power.
Either way, you can have a pretty fast car and still be smog legal. Whatever heads you choose, paired with a FAST intake and small cam, even through shorties and 4.11 gears will easily net you an 11 second car if you can drive.
Straight from the EPA:
"For light-duty vehicles, installation of a light-duty engine into a different light-duty vehicle by any person would be considered tampering unless the resulting vehicle is identical (with regard to all emission related parts, engine design parameters, and engine calibrations) to a certified configuration of the same or newer model year as the vehicle chassis, or if there is a reasonable basis for knowing that emissions are not adversely affected as described in Memo 1A. The appropriate source for technical information regarding the certified configuration of a vehicle of a particular model year is the vehicle manufacturer."
From CARB:
"An engine change involves swapping a car engine with another that is not identical, under California law. The state insists that the newly-installed block must be the same age or newer than the one coming out of the car. It must be from the same type of vehicle, such as a passenger car or light duty truck. If the car is California-certified then the engine going in to the car must also be California-certified. Car owners must make sure an engine change does not increase pollution levels, according to California's Air Resources Board. Car owners must submit their car for inspection after an engine change takes place. This is carried out at a state referee station where the vehicle is subject to an emissions test and checked to see that all required equipment is where it should be under California law."
Not counting labor I swapped my LS1 heads to GM CNC complete heads ($1500-includes springs, valves, porting) and mild sleeper cam ($650 -includes pushrods, bolts, gaskets, LS2 chain) on stock manifolds and stock bottom...passing smog all the time. You already have the stall & gears so you will easily pull 12's all day long with just H/C.
Depending on the smog shop they usually look for the necessities (cats, no engraved heads or headers, smog stuff) and plug in the computer, then you pass. If you have a noticeable radical cam, then you will have an issue but most of them just want to get it done in 20 minutes or less and pass you.
Texas Speed will also do heads without the engraving if your willing to wait or buy a head plate like I did and cover the engraving with the plate on the passenger side. They look exactly as your stock heads only the cast number is 799/243 vs. 241 which the smog guys have never, ever question. I doubt they are trained to check all head casting numbers on all cars, I just don't see that happening.
If your cam is going to be mild, a "Stage 2" set of heads should cover your needs with all the upgrades. I went to Martin @ Tick Performance for my cam, he probably has heads as well.
It is the radical cam or loud headers that usually cause the failed smog test. I've never had a problem. Hope that helps.
Op send your heads here for this package and save money by using YOUR castings on your car. No need for 243/ 799 castings. Sure your car will be down for a bit but not a big deal. I had my heads back fast. Porting cost $1195. Buy some PAC 1218 springs(less than $200 on ws6store.com) and send them with your heads. You will get them back assembled and ready to bolt on. Way cheaper than AFR heads at $2200+.
http://www.advancedinduction.com/LSX...RGMLS1Head.php
I think it would be smarter to invest your money on things like porting your stock castings you already have to save money, get a custom cut cam for YOUR build specifically, do all the supporting mods, and buy a nitrous kit. You would have one hell of a reliable combo that passed smog. Although nitrous kits are not smog legal, they can easily be hidden or partially removed for the test.
Basically California sucks to be a car enthusiast in. Lol. So it's best to not go overboard and just buy another car that does not need to be smogged and build it ***** to the wall. Goodluck with everything man.
Also, if one is willing to hack up the LS1 intake to remove the EGR fitting, I bet it could be epoxied to the LS6 in such a way that the EGR pipe could be cut and fitted to it. Of course, it wouldn't function but would appear stock to pass visual.
