Radiator fluid dispersal
Old Apr 16, 2015 | 04:57 PM
Stewie5409's Avatar
Default Radiator fluid dispersal
Hello all, so I had an internal head gasket leak on my camaro. I did a pressure test on it thus basically filling the engine with rad fluid. I've emptied of all that old fluid and run about three quarts straight through it and it's still milky! Should I just replace the oil and keep up on it?? Or continue pouring oil through it till it's not milky?? Or any other tricks or insight is greatly appreciated. Thank you.
