weird compression test. engine sat for awhile
Old Apr 22, 2015 | 09:29 PM
jz2518's Avatar
Default weird compression test. engine sat for awhile
i got an engine that sat for awhile. the vehicle was wreck from the side. it sit over a year. i had it on the stand and did a compression test and the 2 front passanger side had good readings. 170 both. the other were 120 and one was at 110. i sprayed wd40 and the reads went up to 150 . i still get one on the low side. (rear driver side?)
Old Apr 23, 2015 | 12:52 AM
RockinWs6's Avatar
Ahhh good old number 7, check it out carefully. I'd leak test it and scope it. Number 7 is known for broken rings lands broken pistons etc because it runs so much hotter than the other cylinders.
Old Apr 23, 2015 | 08:50 AM
Darth_V8r's Avatar
Moderator
Yeah, spraying oil in the cylinder and seeing compression increase is a classic "worn piston rings". Spraying oil in and no improvement either means broken rings or a valve isn't sealing
Old Apr 23, 2015 | 12:12 PM
RockinWs6's Avatar
These are low tension rings and you usually don't see wear. Most likely broken from heat or a broken melted worn piston.
Old Apr 23, 2015 | 07:00 PM
jz2518's Avatar
i did a leak down test and notice it was leaking from the intake valve. i guess when the engine seat for a while the valve seats got little corroded. hope it cleans up after a startup.
Old Apr 23, 2015 | 10:21 PM
RockinWs6's Avatar
That's a good thing, better than piston trouble. Maybe fine once its running.
