Suggestions on parts for cam install.
Old Apr 25, 2015 | 10:34 AM
partemisio's Avatar
Default Suggestions on parts for cam install.
So I just got my lq4 swapped 240sx running. I was planning on just driving it as is for a while with stock internals. But, I got a cam from Texas Speed cause of their sale. I knew I had a misfire so I was diagnosing that before taking it apart. I believe the issue is the lifters cause I have great cranking compression (all over 180)but running compression seems low to me (60-70 on the driver side and 90-100 on passenger side). So it looks like I have to pull the heads off the car. My question is, should I go ahead and get a double roller timing chain and high volume oil pump while I have it apart? Or do you think the stock components will be fine? I have new push rods, valve spring, and the trunion upgrade kit already. Is there anything else that I'm not thinking about?
Old Apr 25, 2015 | 04:48 PM
lsxdick's Avatar
Might as well do the timing chain and oil pump. JP makes a nice one, however double rollers are really overkill. Also you might as well replace the lifter trays too if you aren't using a linkbar style lifter. You need timing cover, water pump, and head gaskets and the oil pump o ring if you do the pump.
Old Apr 28, 2015 | 01:40 PM
dallas.ws6's Avatar
Most people change out springs and pushrods and i would go ahead and change out the pump.. maybe try and ls2 timing chain? not too expensive
