Will it run?
So long story short, here's the question. Will the LQ4 run well enough to at least see if the ECM and DIY harness is working with compression numbers that low?
I was going to build a run-in stand anyhow so its not like i am putting an engine I know is tired into the car. I will ultimately rebuild it but i think i'd like to build the harness and have the ability to run the engine first.
Thoughts?
Thanks all!
S.F.
Yank the heads to check/clean/inspect
You already know it sat for a long time so pulling the valves and springs apart can only help. Clean everything, lap the valves back into the seats and perhaps toss some new valve seals in there as those can dry rot and cause smoking issues from sitting in a scrap yard for lengthy periods.
You wont get 200 psi from it but it will definitely run/tune better if it ends up in the 150-160 range.
Yes, tried it both ways with only minor pressure differences
Two hardware store grade bolts in the exhaust manifolds.
Two oddball bolt/nuts holding on the manifold downpipes (studs sheared and drilled out?)
Marks on the heads on the intake side from a Roloc or other stripping disc.
Blue headgaskets (fel-pro?)
Engine came from a 2006 GMC Savana 2500 FedEx van. Cluster was gone so god only knows how many miles it has on it or how FedEx's mechanic of choice took care of it. Block VIN matches the Van so its original and been torn into before. The undersides of the valve covers were significantly dirtier than the heads / valve train so I'm thinking the heads have been gone through at minimum once before.
S.F.
2-8 are marked: 7233 P180 5205 190
1-7 are marked: 7233 R179 5206 220
Anyone know what all that means or why they are different?
S.F.
Get a spring compressor and pop the heads apart. Have them surfaced as the roloc crap can damage the gasket sealing surfaces. If I were you I'd have them surfaced .030" to get 10:1 compression...and if you're up for a quick cheap improvement, pickup some blue or yellow GM valve springs from a vendor like Summit and I have a LS2 cam and some real low mileage valve seals that have been soaking in motor oil. IIRC the springs are only 60 bucks and I'll ship you this cam and seals for cheap.
specs are 204/210 @ .050" and .525 lift. With headers and a tune 425 fly wheel horse would be a great starting point till you build it up at a later date.
S.F.
Used covers are like 50 and the cam gear is 16 from Pace
