Is this a good price for heads and cam package??
Old Apr 28, 2015 | 01:24 PM
dallas.ws6's Avatar
Default Is this a good price for heads and cam package??
Alright guys, so ive been doing some research.. through here and talking to vendors. Im trying to find out if you guys think this is a fair price on a h/c package. So here are the parts as follows..
-Trickflow 220cc As Cast 3.900" Bore
-Powder Metal Guides- Required for use of stock rocker arms
-61cc chamber
-GM TTY LS1 Head Bolts
-GM MLS 5.7- Pair
-Comp Cams Trunion Upgrade for use with my stock rockers
-VRX5-- 236/238 .602/.605 113+2
-5/16" 7.500" Hardened Pushrods
-Front Cover Seal / Front Cover Gasket / GM Waterpump Gaskets / GM Valve -Cover Gaskets
-ARP Crankshaft Bolt
-LS7 lifter kit
-C5R timing chain
-Melling High volume oil pump #10296
And the grand total is 3183.23 including tax shipped to my door with standard shipping from vengeance racing. What do you guys think?... Oh and btw is there anything on this list that you would add that i might be missing?
Old Apr 28, 2015 | 01:36 PM
flintwrench69's Avatar
Not bad, seems legit. I would do ARP head bolts over Gm TTY. Won't be fun angle torquing them stock bolts in an f body & the ARP is much better.
Old Apr 28, 2015 | 01:37 PM
Darth_V8r's Avatar
Moderator
I don't think that's a bad price at all. I would consider going to ARP head studs. Also, your long tubes, if they are smaller primaries, consider going to 1-7/8" primaries. I don't see which intake you are using, but if you are still on the stock LS1 intake, you'll be leaving a lot of power on the table. I'd go to a FAST 92/92 at a MINIMUM with that set up.
Old Apr 28, 2015 | 01:44 PM
dallas.ws6's Avatar
I got the stock intake atm, but i was definetely planning on getting either the fast 92 or 102 still havent made up my mind. thanks for mentioning the studs, ill probably end up getting them... so pricey though lol
Old Apr 28, 2015 | 05:32 PM
Darth_V8r's Avatar
Moderator
Yeah, they are pricey, but like everything else on these things that is pricey - worth it.
Old Apr 28, 2015 | 08:08 PM
kinglt-1's Avatar
Get a Fast and some morel 5315 instead of LS7 lifters. The cam also seems a tad large. The VRX4 would be much better for street driving. Arp bolts are much easier to install in the car.
Old Apr 28, 2015 | 08:31 PM
JakeFusion's Avatar
Super Hulk Smash
Agreed. Do the VRX4, Morel 5315s, and the ARP bolts.
FAST 92/92 would be easier to install. You give up a few ponies vs the 102, but if you go with the VRX4, you'll be going for more avg power vs all out. The 92 would be good there.
Old Apr 29, 2015 | 01:46 AM
dallas.ws6's Avatar
Thanks for the input.. the longtubes i have right now are 1 3/4. I read a thread along time ago on here about guys expirience with 1 7/8 headers.. basically 1 7/8 arent needed untill the motor is roughly around 440+ CI
Old Apr 29, 2015 | 09:32 AM
kinglt-1's Avatar
1 7/8 have been dyno proven to make 8whp over 1 3/4 on a stock 346. On a 440ci motor I would be running 2".
Old Apr 29, 2015 | 10:07 AM
Rise of the Phoenix's Avatar
That depends a lot on what other mods the 346ci has. If it's has heads/cam/intake, going up to 1 7/8 headers is going to gain more than 8rwhp. There have been instances of guys making upwards of 15+rwhp by going with larger primary headers.
Old Apr 29, 2015 | 01:17 PM
BrntWS6's Avatar
Not at all...I picked up 20 rwhp switching over to 1 7/8" and both were kooks.
Old Apr 29, 2015 | 10:18 PM
kinglt-1's Avatar
TSP did a back to back comparison on their 1 3/4 and 1 7/8 headers and gained 8-9hp on a stock 346. Obviously on a engine with more mods the 1 7/8 would show even more gains. Point is 1 7/8 are worth it so I guess we agree.
Old May 1, 2015 | 02:38 AM
dallas.ws6's Avatar
Anyone ever do their H/C swap.. how tough was it? Anything inparticular to look out for?
Old May 1, 2015 | 08:20 AM
#931's Avatar
-61cc chamber
-GM MLS 5.7- Pair
-LS7 lifter kit
-C5R timing chain
Dallasws6, we're are u getting this set up.ive been looking at a head/cam package. Getting ready to pull the trigger.
Old May 1, 2015 | 09:21 AM
SoonerBrad88's Avatar
X2
Definitely upgrade lifters. It's only like an extra $100 for the Morels and I would do ARP bolts over studs. Unless you're boosted or spraying a lot of nitrous I think studs are overkill.
Old May 3, 2015 | 04:31 AM
dallas.ws6's Avatar
Its from vengeance racing
