Oil coming out?
Old May 4, 2015 | 07:03 PM
cabotgsxr's Avatar
Default Oil coming out?
With the transmission removed looking directly Above the real main seal housing there is a opening in the the block in which you can see the camshaft position sensor. What would cause oil to come out of the opening? Please need help bad
Old May 4, 2015 | 11:09 PM
Paul Bell's Avatar
That's MISTER MODERATOR
You should NOT be able to see the camshaft sensor. Is there some of the block cracked off exposing it? Iron or aluminum block, what vehicle?
Pics??
Old May 5, 2015 | 02:31 PM
cabotgsxr's Avatar
Old May 5, 2015 | 02:33 PM
Meth Sled's Avatar
Sub'd
Old May 5, 2015 | 03:47 PM
ryang27's Avatar
That's where the barbell goes I believe. I just bought a btr stage 3 cam, and it came with the new barbell that fits in that spot. It's supposed to keep the oil from running back into the galley after the initial flow pattern. I believe, but someone please back me up on this ..don't wanna be giving out incorrect info.
Old May 5, 2015 | 04:43 PM
LS1MCSS's Avatar
That's not the hole he means. He means the one straight up from the top of the rear cover. I have a 6.0 block on the stand at home. I will look at it tonight.
Old May 5, 2015 | 06:08 PM
Paul Bell's Avatar
OK folks, first, here's what the ports under the rear cover do:
Old May 5, 2015 | 06:14 PM
Paul Bell's Avatar
The cam sensor passes through the top of the block then through the open space. Then it goes back into the block. This is where the seal on the sensor seats.
Old May 5, 2015 | 06:15 PM
Paul Bell's Avatar
If you're having oil coming out from this exposed section of the camshaft sensor, I'd say the O-ring on it is bad, missing or dislodged.
Old May 5, 2015 | 07:31 PM
02blksscmro's Avatar
Can't argue a post like that can you?
Old May 6, 2015 | 07:48 AM
RockinWs6's Avatar
Excellent post!
Old May 6, 2015 | 09:12 PM
joecar's Avatar
It's pretty hard to fling oil up past the CMP sensor and to have it come out of the cavity above the crossover passage (altho it is not impossible)...
maybe, just maybe, oil under pressure is pushing out of the crossover passage (i.e. getting pushed out of the crossover passage and out from between the block and the rear cover)... ( maybe )
( I say this because the cam reluctor does not get lubed, whereas the crossover passage contains pressurized oil )
Old May 7, 2015 | 09:06 AM
LS1MCSS's Avatar
My guess would be a bad or missing o-ring.
Old May 7, 2015 | 08:19 PM
cabotgsxr's Avatar
Where can I get just a replacement o-ring from?
Old May 7, 2015 | 10:25 PM
Paul Bell's Avatar
The LS1 cam & crank sensors are both -113.
http://www.marcorubber.com/sizingchart.htm
