Head bolt broke off in block ls1
Old May 15, 2015 | 06:17 PM
LsPrideOrDie's Avatar
Default Head bolt hole stripped in block, head studs?
First, the arp bolt broke off in my block, passenger side, very far back bolt, under the valve cover, I ended up getting the broken part out of the block, but kind of messed up some threads, in the block. Well I tried to put the head back on and ended up stripping the block. Question is, I'm thinking of buying a head stud kit, and put a heli-coil on the that one head stud, since it they only have to go hand tight. You guys think it'll hold fine?
