cam timing
Old May 14, 2015 | 02:16 AM
ls1_camaro_z28's Avatar
Default cam timing
I've looked and searched but can't find what I'm looking for. I have the double roller timing chain from comp cams. I need to know what degree to set the crank gear. It has advanced settings and retarded settings. Car has 76mm turbo.
Old May 14, 2015 | 10:13 AM
farmington's Avatar
zero. then check it to see if its where you want it. if not, THEN adjust
Old May 14, 2015 | 08:24 PM
Ok thanks for the help
