I Want To Smack A 5.0 Silly..
I want to walk on a 5.0. Obviously it's going to take a lot to get there. Here's a list of mods that I am considering (2004 GTO A4 - Cosmos Purple Metallic). Please give me some input.
1.) CAM - Polluter Cam v1
2.) HEADS- TFS 215 Heads
3.) INTAKE - Fast 102 ported by Tony Mamo
4.) THROTTLE BODY - Fast 102 Throttle Body
5.) LONG TUBES - Kook's 1 3/4 to 1 7/8 merge
6.) DUAL E-CUT OUTS - about 12 to 16" from headers
7.) X PIPE
8.) GEARS - How low should I go with my gearing? I don't mind 4.56, just don't know if that's a good idea or not. My car stays in town (as in I don't ever travel) and I only live 6 miles from my work. Most of my trips consist of highway miles.
9.) STALL - Should I do a 4400 stall? Again, I really don't care about fuel economy. I just want to smack around a 5.0 Mustang.
Obviously there are other parts that I need to be bought. Such as valve springs, pushrods, lifters, etc. I just want to know how this combo would fare out.
Another note, I will be doing weight reductions. GTO's have a lot of stuff that you can take off. I'd like to get it around the weight of an F-body (3400 poundsish). But that's a whole other subject.
Thoughts guys? All help appreciated! Car will be raced on 1/8 mile track. We do not have a 1/4 mile around here.
NW TB have a much better reputation for ease of tuning by members
On this site compared to the Fast TB. Have Tony spec a cam for your
Heads and intake.MMS 220 Heads, Fast 102, Cam, Long Tubes, Exhaust etc
You can pick up 120-150 RWHP to the wheels. With Tonys set-up I
Doubt you would need/benefit from more then ~ 3600 RPM Stall.
You will need to beef up the rear gear/suspension to keep from breaking.
3.90:1 Gears with some weight reduction will be Plenty for your
Goals/Needs.
I'd run a 4000 or 4400 stall. They aren't that bad.
I'd run straight 1-7/8" headers. Cutouts aren't necessary if you run a 3" x-pipe with high flow mufflers. If you want something quiet, run the cutouts and an actual muffler vs bullet-type race mufflers.
Heads - TFS 215 are okay, but I'd recommend doing the TFS 220s worked by Tooley with lightweight valves, PM guides, hand porting. It's a better value and won't give up much to anything else.
If you go MMS 220s, get the YT Ultralites with 10mm studs. Otherwise, I'd do stock rockers with BTR Trunions.
3.73 is plenty of gear with an automatic.
TB - I have both the NW and the FAST 102. Both tune the same. The FAST may run out of IAC sooner, messing with cold starts, but it actually drives a little better with the low pressure zone for part throttle.
Easiest way to beat a 5.0 is to install a Money Maker nitrous kit and run a 200 shot.
Goals/Needs.
As for the rear, it's not an F-Body. I think I'll be alright with some 3.73's or and 3.9x's. This will be a pretty good debate in my head since stock, these come with 3.43's from the factory (even the automatics). Just need to make sure that I get my money's worth on a 1000 dollar swap. Gears for these cars aren't cheap.. :/
Need a slightly bigger cam! The MMS heads do not "like"
Smaller cams they just do not need as much duration to deliver
The same or better performance. The sweet spot with the stock
Stroke is about 227*-231* Intake and for NA up to 7000 RPM
with a good exhaust system is +4* more for the exhaust duration.
The MMS220 is perfectly Sized for 5.7-6.0 as well as 383".
The beauty of the small/medium cam with the best heads you
Can get is the throttle response at 2500-3000 RPM along with
Peak Power @ ~ 6500-7000RPM! That's the "Have your cake
& eat it too" scenario that Tony is always talking about. There
Is a thread in the Dyno section "AFR205 make 500+ with auto
And big stall and big cam" that head design is 12+ years and 2
Generation design changes ago.
Check out the MMS220 announcement thread below.
I agree with Jake on the 1 7/8 Headers and the 3.73:1 Gears
Also!
In PM, I revised my cam selection to a 228/232 111 StreetSweeper-HT. It'll move the GTO and make plenty of power. Pair with either the MMS 220s or TFS 220s worked by Tooley and then you have something. Just depends on budget. A port-matched FAST by Tooley, worked TFS 220s, and BTR Trunions would be cheaper than MMS 220s, Mamofied FAST, and YT Ultralites. Power difference between the two with that cam would probably be 5-10HP.
227*/231* but with a 114* LSA + 2-3* ADV. I would bet the different
Head/Intake combos with above cam would be 10-15+ to the Favor of
MMS with better drivability, but less Lope if that is important to the
OP which I suspect might be. Could still do the BTR Trunions or the
CHE Bushings with MMS220s as well.
Good Pt. I totally agree! Power is 10 X more important to me
Than Lope/Sound and tuning for sound is the way to go vs
Camming for sound. I suspect sound is much more important
To OP than me (on the other side of 50 lol).
The TFS 220s would make close to the 215 numbers. Point is, with everything supporting, I can see more than 470 out of either combo. If you optimize the **** out of it, maybe 480.
500 is hard to do. Harder to replicate on different dynos.
If you're doing an honest 470 with an LS1, your car is going to be pretty damn fast for a 15 year old car.
I don't think the as cast 220's out of the box would do as well as you suspect. One pair might but three pair wouldn't.....as cast stuff is inherently all over the place.....too many moving targets and there is usually extra material etc. in as cast trim that effects flow pretty dramatically. Hence the benefit of a CNC program which knocks the "window of fail" down dramatically but even that isn't perfect but alot closer in tolerances than any as cast port.
Trust me on this....its very difficult to get an *** cast port to flow big numbers out of the box. The mark of a really good one is an as cast port that doesn't need alot of work to flow respectable numbers. And by no means am I bagging on the TFS 220....this is a very un-brand specific comment. An AFR as cast BBC is very good but it has its limitations just like I mention although with the AFR as cast BBC we went the extra step and had the bowls optimized with a quick CNC bowl blending program so technically this head was more of a hybrid.....partial CNC ported because of exactly the point I was making above.
Its extremely difficult to get any as cast port out of the box moving alot of air (or should I say close to similar sized heads in CNC trim). I would run a smaller CNC port than a larger as cast port.....area under the curve would be alot stronger and it would make more power as well because the peak flow would be higher in the optimized CNC port assuming it was a decent port design and the CNC replication of that design was done well. The full CNC TFS 215 is a good piece and has proven itself out in the field.
I may be porting a set of cast TFS 220 heads very soon (waiting on the customer to confirm this is the direction he wants to go....he already owns them).....If I get the chance I may update this thread with some stock numbers when I do.
Cheers,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
I'm just going by what Tooley said. He doesn't do a lot of work with them when he cleans them up.
I'm not saying you did run from 40, I'm just warning against it since its everyone's favorite starting point. My point to all this being that you can build power to the moon but if it's not used correctly, you still might be seeing a slower cars tail lights.
