Need help with lq4 build!!
Ported stock heads, 11.0:1 Comp minimum, 1 7/8 headers,
X Pipe with 2 1/2" dual exhaust minimum. Mamo Ported FAST
TRUCK Intake worth a bunch also (20+minimum)
Hot Rod Magazine too a 6.0 added gto headers, 40 series flowmasters, and a tune. Results was 410 horse and 440 ft lbs of torque. That was with the FACTORY cam and the with less performing 317 head.
A 208/212 duration cam would add 60 hp at the crank roughly over the factory cam (tested on a 5.7 ls1) .... A bigger 224 cam should add even more power than that. Good luck for your project.
