solid roller in ls1
Old May 31, 2015 | 03:02 PM
GMtechmatt's Avatar
Default solid roller in ls1
anyone running a solid roller on a stock bottem end ? if so how much lift? and who makes a good solid roller
Old May 31, 2015 | 05:39 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Speak with Kip @ Cam Motion, Low Lash Solid Rollers are
Much more street friendly than solids of the not to distant
Past. Lift is primarily determined by where the heads stall
Or stop gaining CFM. Makes no sense for a .700" lift if heads
Stall @ .625" for example. Check out SpeedTiggers build
And results with his LLSR from Cam Motion.
