milling and thinner head gaskets ok?
In fact what you're doing is pretty good, increasing compression and better quench.
runs great and is great on 93 octane. The real way to see if your car can run 93 octane is to determine the dynamic compression ratio. Your cam greatly effects this and the calculator uses the cams ABDC number to calculate it. Mine is at 8.8:1, once you get to about 9:1 dynamic your looking at needing more than 93.
