Need some help please take a look.
In this time frame I have burnt about 2qts of oil in 500 of the 6. I had the oil changed today and no sooner than I get about 10 miles I start to hear my motor knock. So I have it towed back to my place after I got off work pulled the valve covers hopeing it was just a rocker arm that backed out. That wasn't it so I pulled the spark plugs and found that the number 5 cylinder's plug was completely covered in oil. I have to do a leak down and compression check this weekend if I get the chance.
So does anyone have any ideas as to what my knocking might be or where I should start to look next? Any ideas are better than none and right now I'm open to anything.
Thanks
Brandon
Any ideas on why my motor would start to knock? I checked the rocker arms and all were tight don't know if they still had 22ft lbs of torque, but they didn't move other than alittle side-to-side. Springs are good still as well. So I'm thinking that after the leak down and compression test I will have to pull the heads again. Would I be correct to assume this or is there another avenue I could take? Once again thanks for the replies and keep them coming.
Brandon
