5.3 crank end play?
Half the engines I build I have to sand the thrust surface lightly and open up the end-play (no exaggeration).
Perfection is .0035 - .004 IMO leaving a couple of thou on each side for the oil...crank floats on the oil and doesn't even move in operating conditions but is completely free. If the clearance is too tight.....not enough oil.....too loose and you lose the hydraulic support from the oil and you can get some light hammering back and forth, especially in a stick car. I'm kind of a stickler on end play.....watch how much better it spins when you add that extra thou or two.....crazy how so little makes the difference but it does.
-Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
