New cam/timing set questions
So I put on a Coyles timing set along with a new cam. I put the crank sprocket on but also put the part that the oil pump is pushed by and it is covering up the marks. So my question is, since my heads are off and I can "see" when #1 is at TDC, can I just ensure the cam mark is at 6 o'clock while #1 is at TDC and be fine? Seems like I should be able to but wanted to confirm, this is my first engine build in over 20 years...
