Head valves doubt; Some help here???
Old Jul 25, 2015 | 07:43 AM
Mike Cordero's Avatar
Default Head valves doubt; Some help here???
I have a set of 243's heads that came from a Corvette (sodium filled heads) but valves were lost. Can I use regular valves from another regular cast LS1 heads? Same size, same length between the sodium filled and the regular ones?
Old Jul 25, 2015 | 05:19 PM
Darth_V8r's Avatar
Moderator
You could use the valves from a 799 head but won't be sodium filled.
Old Jul 25, 2015 | 08:24 PM
What about other LS1 heads valves; from 241's or others?
Old Jul 25, 2015 | 08:26 PM
JakeFusion's Avatar
Super Hulk Smash
Valves are different length in the LS6. It's .050" longer.
Old Jul 25, 2015 | 08:39 PM
rpturbo's Avatar
How is that possible? Don't they use the same pushrods?
Old Jul 25, 2015 | 09:50 PM
redbird555's Avatar
yes they do but the cam has a smaller base circle in an ls6
Old Jul 26, 2015 | 04:33 PM
Having the 243's with sodium filled valves and the LS6 cam, what's the size (lenght) of push rods needed?
Old Jul 26, 2015 | 06:40 PM
Darth_V8r's Avatar
Moderator
While you've got the heads off will you be changing lifters? Strongly consider this if you plan to run heavier than stock springs.
Old Jul 26, 2015 | 07:17 PM
I have new LS7 lifters.
Old Jul 26, 2015 | 07:33 PM
A.R. Shale Targa's Avatar
0.0236"...................
Old Jul 26, 2015 | 07:37 PM
New, yellow springs tat comes with the LS6 cams. Which push rod length I will need?
Old Jul 26, 2015 | 10:30 PM
Darth_V8r's Avatar
Moderator
7.400 should work but you should measure to be sure
