Come in help with build-
Old Jul 26, 2015 | 09:19 PM
InsaneLs1SS's Avatar
Default Come in help with build-
Hello,
Current setup is as follows. 2002 Z28 A4, w/ ac/ps
Engine: 347 LS1
5.3L heads W/oversized valves (#706 heads)
Comp LSR cam 231/239 .617/.624 113 LSA w/ New pushrods / Valve springs
Wiseco Pistons
K1 Rods
LS6 Intake manifold
LS7 lifters
Ls2 Timing chain
FAST 36# injectors
Aero 340 LPH fuel pump
Car made 378/380 on motor and 494/433 on a 150 shot with a bigger fuel jet then recommended.
The car seems to lack some power on motor at the top of 3rd.
Id like to try and fix this with a more aggressive cam.
Do i need a special cut cam to work with these heads/valve setup? What cam may you recommend? I'd like it to be pretty aggressive on motor with the nitrous as just the extra giddy up when needed. This is not a daily fyi.
Sorry for maybe the ridiculous question but i didn't build this car my uncle did and i inherited it as a wedding gift.
Thanks,
Old Jul 26, 2015 | 09:49 PM
A.R. Shale Targa's Avatar
That is a pretty aggressive cam for a 5.7, perhaps the valve springs are just shot and it's considerably more noticeable in the third gear when the engine is building rpms at a slower pace.
A set of MMS220 heads and a matching 92mm FAST intake should put you in the mid fours at the tire on *****
Old Jul 26, 2015 | 09:58 PM
thats where i'd like to be 420ish motor.
Old Jul 26, 2015 | 10:34 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
I agree with A. R. Shale Targa, MMS 220 heads, 227*/231* cam, +FAST 92=
420+ RWHP With stalled auto, better performance bottom to top,
along with Better Driveability as well.
Old Jul 26, 2015 | 10:54 PM
What about switching to e85 with my current setup. I'd just need bigger injectors and a tune.
And where can I find this mms220 head, Google isn't being friendly.
Old Jul 27, 2015 | 05:45 AM
HCI2000SS's Avatar
I run those heads with a cam more aggressive yet. It's not the cam that you have that's causing the problem
