Spacers for windage tray help
Old Aug 5, 2015 | 10:21 AM
transamfreak01's Avatar
Default Spacers for windage tray help
Putting in the 408 and I was told the windage tray needs 1/4" spacers.... Can I get these at a local store or do I order them from somewhere? If someone can tell me exactly what I need I would appreciate it. Thanks
Old Aug 5, 2015 | 11:37 AM
Undertow74's Avatar
Just get some appropriate sized washers and you should be good to go.
Old Aug 5, 2015 | 11:58 AM
conan's Avatar
X2 ^^^
I used 1 flat washer each stud and had enough clearance for the rod bolts on my 4" stroke crank. Just make sure to spin the engine over and check that everything clears.
Old Aug 5, 2015 | 02:30 PM
imma_stocker's Avatar
Smacked my baffle/windage tray with a mallet until clearance happened... don't recall anything special besides that. Stock fbody pickup, pan, trays, gasket, hardware, etc.
Old Aug 5, 2015 | 03:22 PM
Haha I think I'll stick with the washers
Old Aug 6, 2015 | 08:15 AM
jrpimp00's Avatar
I used some thin nuts to space mine down on my 408.
Old Aug 6, 2015 | 09:30 AM
svede1212's Avatar
My 383 just needed washers. Besides bore it's pretty much the same thing
