overheating idle and 6th gear
Flip , I have never been able to get the air out just by filling the radiator .The only way I have been successful it to take the upper radiator hose off and fill from there while the steam line is disconnected . Once I started doing it this way I have never had a problem since . I would give it a try . I would bet you still have air in the system .
remove hose from steam crossover pipe and connect a length of clear tube to the steam crossover pipe, and run engine, you will see air in the tube... when there is no more air (only coolant) reconnect the hose back onto the steam crossover pipe.
( using "Garage Talk" from my phone I was trying to add your post as a second quote to my post, but it was not working )
