Weird engine problem need help!
Alright so for the last two days my car would start up fine and sound normal. But randomly while driving my rpm will go up and down and the car then dies out with a huge misfire noise. It then starts back up no problem but shows no rpms on the gauge . so confused. If i lay off the gas it stops it from dying. Battery and alternator are good and it has new plugs and wires. What could it be?
. Last edited by Vegas02ta; Aug 11, 2015 at 07:21 PM. Reason: Stuff
Hmm Usually it will pop a cel if that is an issue. If you have hp tuners go on Mitchel check the parameters for the cam/crank sensors/fuel pressure / injector loads it should tell you that they all are at or use a live data logging feature scanner reader
. I would start the the first post i did then move onto the deeper things since its always best to start where you last touched something
